coopers308 Offline
#1 Posted : Tuesday, 2 September 2008 3:34:50 AM(UTC)
coopers308
Hi,
My question today is about the numbers following the prefixs in holden engine numbers. Does anyone know how you can find out at which number a model started and finished - so you can tell if is an early or late example? My question is more directed at 6 cyls as the V8's have date codes to go by.
#2 Posted : Tuesday, 2 September 2008 3:53:56 AM(UTC)
Hi cooper308.
The 6-cyl engines do have casting dates. As a matter of, so do most large castings including inlet manifolds.
The 6-cyl date code is on the side of the block near the oil filter.
Dr Terry.
coopers308 Offline
#3 Posted : Tuesday, 2 September 2008 3:57:33 AM(UTC)
coopers308
Thanks Dr Terry i never new that!
