dagwoodone Offline
#1 Posted : Thursday, 4 September 2008 7:59:15 AM(UTC)
dagwoodone
how do you identify a genuine brabhan torrie by numbers what should i look for as i found a so called torrie that the dude is claiming to be a Brabham other than the badging which is the obvious? cheers
coopers308 Offline
#2 Posted : Thursday, 4 September 2008 8:10:35 AM(UTC)
coopers308
Im not that sure on body and vins etc but i think engine number prefix is 23HB, could be wrong though.
coopers308 Offline
#3 Posted : Thursday, 4 September 2008 8:10:35 AM(UTC)
coopers308
Im not that sure on body and vin's etc but i think engine number prefix is 23HB, could be wrong though.
dagwoodone Offline
#4 Posted : Thursday, 4 September 2008 8:21:43 AM(UTC)
dagwoodone
Thats a start thanks dude
#5 Posted : Thursday, 4 September 2008 4:22:06 PM(UTC)
23HB is also for series 70 engine, brabham engine had 2 CD stromberg side draught carbs. The option code was XS5 , I do not know if this was on the plate though, brabham option was available on S and SL, 2 door only. seris 2 had a sport dash inc tacho, a
#6 Posted : Thursday, 4 September 2008 7:10:40 PM(UTC)
code is not on the tag, this started in 73 in Brisbane and not made other tags till part way through Commodore.
If painted Warwick yellow or bright blue metallic then it is one. Other colours for 69 are silver mink and picardy red.
Hard to pick an e
#7 Posted : Thursday, 4 September 2008 7:10:40 PM(UTC)
If painted Warwick yellow or bright blue metallic then it is one. Other colours for '69 are silver mink and picardy red.
Hard to pick an
