#1 Posted : Monday, 8 September 2008 10:50:23 PM(UTC)
Trying to identify some wheels that are on my sandman PV that I have just bought. They resemble hotwires but are flatter and the actual spokes are of rubber they are made by polyweld the same manufacturer of the honeycombe wheels on the HZ GTS. The wheels are date coded 10/1978 the van is 9 month 1978. I was wondering as well if it was possible to option the sandman with these wheels. Any help appreciated.
#2 Posted : Tuesday, 9 September 2008 1:08:19 AM(UTC)
Do they look identical to HJ-HZ polycast 14x7 rims? I'm pretty sure the polycast rims were optional on most HJ-HZ except for HX LE which came standard with a gold version of them. If they are another style they will probably either be dealer fit or afterm
#3 Posted : Tuesday, 9 September 2008 1:08:19 AM(UTC)
Do they look identical to HJ-HZ polycast 14x7 rims? Im pretty sure the polycast rims were optional on most HJ-HZ except for HX LE which came standard with a gold version of them. If they are another style they will probably either be dealer fit or afterma
#4 Posted : Tuesday, 9 September 2008 2:57:24 AM(UTC)
I meant to write polycast not poly weld no they arent honeycombes they are a hot wire type. I beleive they may have come out on camaros. Possibly they were a dealer fit like you suggested as they were available from the same company that makes the honeyco
