#1 Posted : Monday, 15 September 2008 3:15:15 AM(UTC)
Gday
Whille searching performance head info i find varrying degrees in reference to heads.18 / 23 ect
What does this relate to ?how can imeasure my existing heads for degrees.
Thanks for your help on such an amatures topic
hope my question makes sense
coopers308 Offline
#2 Posted : Monday, 15 September 2008 3:51:53 AM(UTC)
coopers308
It refers to the valve angle in relation to the deck surface, if you have any type of street engine theres is probably no point even checking as you would have 23 degree heads. The 18s are top end stuff very expensive as lots of other stuff has to be cha
coopers308 Offline
#3 Posted : Monday, 15 September 2008 3:51:53 AM(UTC)
coopers308
It refers to the valve angle in relation to the deck surface, if you have any type of street engine there's is probably no point even checking as you would have 23 degree heads. The 18's are top end stuff very expensive as lots of other stuff has to be c
