#1 Posted : Monday, 15 September 2008 6:17:02 AM(UTC)
Hi All,
Buggered up my ignition barell over the weekend and now trying to replace with a good 2nd hand unit.
Have taken the honeypot off and now trying to get the barell out. How does this come out? I have looked, looked and tried cannot work it out.
Any helps would be great....It is in a HJ Ute....
Jamie
HQforme Offline
#2 Posted : Monday, 15 September 2008 6:43:01 AM(UTC)
HQforme
There's a trick that was mentioned by my auto-electrician mate. The release is hidden. You have to use something sharp and actually punch a small hole so you can depress the catch that holds the barrel in. Only, i'm not sure how to recognise the spot wher
"Silly modern cars"
HQforme Offline
#3 Posted : Monday, 15 September 2008 6:43:01 AM(UTC)
HQforme
Theres a trick that was mentioned by my auto-electrician mate. The release is hidden. You have to use something sharp and actually punch a small hole so you can depress the catch that holds the barrel in. Only, im not sure how to recognise the spot where
"Silly modern cars"
jabba Offline
#4 Posted : Monday, 15 September 2008 4:53:25 PM(UTC)
jabba
The hole is there, a tiny slot about an inch in from the barrell head. If you look at the replacement barrell, you will be able to see the metal tang that sticks up that you need to press to release. If you line the new one up against the old, hten you
HZute-efi-VS5L Offline
#5 Posted : Monday, 15 September 2008 6:04:57 PM(UTC)
HZute-efi-VS5L
sometimes the slot is still hidden a bit. when its cast there sometimes is a small skin over the slot. if you push on the area where the slot is you will bust through.
This question comes up alot! I think next time i pull one out i will make a guide
www.stickthisdecals.com.au
#6 Posted : Tuesday, 16 September 2008 7:07:07 AM(UTC)
Guys,
Thanks.....After the advice here, got it out!!!!
Had tried and could not see....After highlighted where it is, could not believe i did not see it in the first place.
Jamie
