Bossy Offline
#1 Posted : Monday, 15 September 2008 6:24:48 AM(UTC)
Bossy
My XP has a speedo that wanders all over the place. It goes from 20 to 60 while I'm doing 40. It also makes awful noises! How do you repair them?
www.earlyfalcons.com Offline
#2 Posted : Monday, 15 September 2008 8:00:55 AM(UTC)
it could quite possibly be that your cable isn't fixed into the back of the speedo correctly. reach behind the speedo and undo the cable, pull it away then push it back in and do up and see if it makes a difference. it only does up by hand tightness and d
sly376 Offline
#3 Posted : Sunday, 12 October 2008 9:50:34 PM(UTC)
sly376
sounds like the speedo cable is dry inside, try spraying some spray grease down the guts of it. Or replace the cable.
#4 Posted : Monday, 20 October 2008 8:54:46 PM(UTC)
sly376 is probably right there. Here's how I used to do it. Undo the speedo cable from the back of the speedo head. Get a piece of cardboard and put a hole in the centre of it using a philips head screw driver. Get a bit bit of grease on two fingers and s
Bossy Offline
#5 Posted : Saturday, 25 October 2008 9:46:23 PM(UTC)
Bossy
Thanks for that guys. The grinding sound seems to have stopped by itself. Will lube cable....
This page was generated in 0.088 seconds.
