kanks Offline
#1 Posted : Monday, 15 September 2008 11:05:30 PM(UTC)
kanks
hi is it possible to romove the snout as it seems a bearing has gone and the only place i can find to repair is sa .i am runing car without supercharger and was hopeing to still drive car without sc connected and snout disconnected.thanks
#2 Posted : Monday, 15 September 2008 11:22:02 PM(UTC)
I think it is as Yella Terra make a replacement snout so it's got to be possible.
If at first you don't succeed then skydiving is not for you.
#3 Posted : Monday, 15 September 2008 11:22:02 PM(UTC)
I think it is as Yella Terra make a replacement snout so its got to be possible.
If at first you dont succeed then skydiving is not for you.
#4 Posted : Monday, 15 September 2008 11:34:30 PM(UTC)
The snout does come off, but it's not advisable to run around with it off, as you will open up the crankcase (gears) to all the atmospheric dust crud floating around, which will be attracted to the oil residue, and destroy it when you put it back together
#5 Posted : Monday, 15 September 2008 11:34:30 PM(UTC)
The snout does come off, but its not advisable to run around with it off, as you will open up the crankcase (gears) to all the atmospheric dust crud floating around, which will be attracted to the oil residue, and destroy it when you put it back together.
kanks Offline
#6 Posted : Monday, 15 September 2008 11:45:57 PM(UTC)
kanks
thanks have been runing car with no belt for two weeks seems to be allright .has anyone tried changing bearings on these at all .as anyone i ask have never heard this problem before
