Ado Offline
#1 Posted : Wednesday, 17 September 2008 8:19:27 AM(UTC)
Ado
A mate has the ability of finding injected 202 vks. Has at least two of them all complete. Wondering what an unlisenced one may be worth and whether you can run it on unleaded. Thinking of slotting an injected 202 in a UC torana. Maybe with a vk 5speed. Are those boxes any good. Any advice on injected 202 good and bad points would be great. Nissan 3.0 conversions not suiterd to this bush mechanic. Thinking efi202 would be easier.
HQforme Offline
#2 Posted : Wednesday, 17 September 2008 9:16:34 AM(UTC)
HQforme
Yes you can run it on unleaded, but you'd need to put additive in with every tank. I think VK's were the last of the leaded cars?
They're horrible for gremlins to be honest, but when they're working, they're sweet cars.
"Silly modern cars"
HQforme Offline
#3 Posted : Wednesday, 17 September 2008 9:16:34 AM(UTC)
HQforme
Yes you can run it on unleaded, but youd need to put additive in with every tank. I think VKs were the last of the leaded cars?
Theyre horrible for gremlins to be honest, but when theyre working, theyre sweet cars.
"Silly modern cars"
#4 Posted : Wednesday, 17 September 2008 9:39:04 AM(UTC)
The VK EFIs are great for conversions to earlier Holdens.
The VH/VK 5 speed are weak as.
This is why they only fitted them behind the 2.85L VHs and not the 202 VHs. They wont handle the power of the EFI 202.
I have regularly picked up running EFI VKs f
#5 Posted : Wednesday, 17 September 2008 10:05:07 AM(UTC)
i got one i took the EFI off and changed to a 465 holley and bolted it to an aussie 4speed the Five speed is crap its a sigma gear box.
The EFI motor is a good motor it has biger valves and the crank is better.
It will run on unleded with flash lube an
#6 Posted : Wednesday, 17 September 2008 3:46:10 PM(UTC)
EFI valves are the same as a carby VK 3.3 I thought? So is the crank? And a VK EFI cam is a reasonable cam to start with - Campbell that reminds me I have to send you the EFI cam profile. Will try to do tonight.
________________________________________
Ado Offline
#7 Posted : Thursday, 18 September 2008 1:20:19 AM(UTC)
Ado
Sounds like a good conversion. I could not belive how smooth the efi202 is when i went in my mates car. Maybe a m21 might do the trick for a gearbox.
Thanks alot.
#8 Posted : Thursday, 18 September 2008 2:33:19 AM(UTC)
M20 will be better behind a 202. No difference in strength either.
#9 Posted : Thursday, 18 September 2008 2:43:56 AM(UTC)
If your really set on a manual. Fit one.
But I have had a few EFI VKs, and IMHO they are great with the Trimatic, fitted with a Gemini torque converter.
With 225/50/16 tyres I ran a 3.08 LSD rear. The VK was like an over sized Go kart.
The Gemini conve
kraul Offline
#10 Posted : Thursday, 18 September 2008 2:46:16 AM(UTC)
kraul
iv converted my ute to vk efi. Its simple and creates a much nicer car to drive. I find my that the torque gain from the swap makes 1st gear in the m20 not needed half the time. The difrnt ratios in the m21 would be intresting to try.
Guest (5)
