HQwagon202 Offline
#1 Posted : Monday, 22 September 2008 12:38:34 AM(UTC)
HQwagon202
i have HQ wagon with a trimatic, if i was to convert to a supra 5 speed which pedal box would i need to get? one from a HQ or a later model?, i have had numerous differnt opinions. i want to use a hydraulic clutch set up
suggestions to stay with a 3.36 diff or go to 3.08. The car is NOT a daily driver but is used on the odd accasion and usually not in traffic
many thanks
#2 Posted : Monday, 22 September 2008 3:54:37 AM(UTC)
Talk to whoever does the hydraulic conversion, they will tell you which to use. Stay with 3.36 with a 5 speed.
HJHeaven Offline
#3 Posted : Tuesday, 23 September 2008 4:55:15 AM(UTC)
HJHeaven
Is a 3.36 better with the 5 speed gear box than a 2.78.
What would improve if i were to switch over to the 3.36 of other ratio diff?
Thanks in advance
Mark
I am not allowed a mistress so i got a GTS - and its better
A GTS/4 is a monaro - so nuuur
special-k Offline
#4 Posted : Wednesday, 24 September 2008 5:02:54 AM(UTC)
special-k
The 3.36 will be a lot better ratio.The 2.78 will be to tall the problem that you will have is goin back to 4th on the slightest of hills
HJHeaven Offline
#5 Posted : Wednesday, 24 September 2008 8:36:45 AM(UTC)
HJHeaven
Thanks Special K
I havent really noticed that sort of a problem.
Mind you the engine has had a little work and maybe that makes the difference?
Will i get any more fuel efficiency out of it?
Mark
HQwagon202 Offline
#6 Posted : Thursday, 25 September 2008 1:47:47 AM(UTC)
HQwagon202
so the way to go is the 5 speed supra with the 3.36 diff ratio
now where do i find and get installed a hydraulic clutch set up??
hmmmmmmmmmm
thanks guys
This page was generated in 0.095 seconds.
