basketcasebear Offline
#1 Posted : Monday, 22 September 2008 3:54:24 AM(UTC)
basketcasebear
hey yall
early last year i got a dipstic masqurading as an auto elec to work on my 308 conversion.
the F.Wit lost a small nut from the coil, sitting above the carby, i searched with mirrors and magnet to make sue it had not fallen down into the inlet manifold,
could not find it,
today 308 started making a real serious racket,y sound,
just wondering on your thoughts?
could the nut have finally lodeged in between the valve and head?
i know i will have to take rocker cover off, but wondering if it could be something else, and or is there maybe other ways to fault find such problemo?
your feedback appreciated,
it definately sounds like head tappet rackety sound.
bcb
or
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
hz dude Offline
#2 Posted : Monday, 22 September 2008 4:31:25 AM(UTC)
hz dude
So what your saying is you think that the nut has fallen into the engine
and has got stuck in the head or got stuck in the valve camber if so
what about a compression test or pray and hope it passes free without
any damage good luck dude your gunna n
#3 Posted : Monday, 22 September 2008 6:55:26 AM(UTC)
basketcasebear
hey thanks hz dude,
if i had more knowledge on engine sounds it might tell me?
this same auto elec, broke my starter motor, surround,, then tried to charge for it,,
thats why i have battling away, doing most things myself,
i am in the position of deci
DOH!!!
trubluhq Offline
#4 Posted : Monday, 22 September 2008 8:59:20 AM(UTC)
trubluhq
Hi BCB,
If the nut was lost during electrical work maybe the nut went into the carb, and is now rattling around the valves/pistons.
Use a long handled screwdriver against your ear to find the BAD cylinder. One will be LOUD. If u are lucky, find the
#5 Posted : Tuesday, 23 September 2008 5:52:08 AM(UTC)
basketcasebear
hey trublu,
this is what i thought? rattling round, or getting stuck in valve opening,???
i have been worried about it ever since that idiot lost the nut,
will stick screw driver in my ear, and against head and block,,
as for removing head, well would
DOH!!!
trubluhq Offline
#6 Posted : Tuesday, 23 September 2008 6:10:02 PM(UTC)
trubluhq
hi BCB,
Actually put handle of screwdriver to ear ! Not as u have stated hehe.
Now if the sparky was doing sparky stuff I cant see why the rockers would be off and a nut got in. A nut if ingested into the engine will be the gap between piston and v
#7 Posted : Wednesday, 24 September 2008 5:47:25 AM(UTC)
basketcasebear
hey trubluhq,
i know u dont put screwdriver in ear!! everybody knows that!! cause it might fall in !!
the sparky lost nut, while workin above carby, with air filter off,,?
tried looking at taking rocker covers off today, and will need special tool to g
DOH!!!
#8 Posted : Wednesday, 24 September 2008 7:49:09 PM(UTC)
A mate of mine dropped one of those tiny spring washers that were on the screws that hold the carby top on his 186.
It made a terrible clatter and head removal revealed that it had been hammering on the top of the piston pretty hard.
#9 Posted : Thursday, 25 September 2008 6:36:04 AM(UTC)
basketcasebear
bugger J5.0,
i hope it isnt that, cause i was hoping to get her up to queensland before i did motor up.
oh well, we will find out,
might have to put that deinjected 304 in her?
bcb
ptpro
I dr
DOH!!!
#10 Posted : Thursday, 25 September 2008 7:09:48 PM(UTC)
#11 Posted : Thursday, 30 October 2008 4:53:14 AM(UTC)
basketcasebear
hey yall
DOH!!!
#12 Posted : Thursday, 30 October 2008 4:55:47 AM(UTC)
basketcasebear
and yes jim5.0,, i would love to put a deinjected 304 in her!!!
bcb
ptpro
DOH!!!
#13 Posted : Thursday, 30 October 2008 9:25:57 PM(UTC)
Busted rocker bridge. When I worked in a Holden Dealer spare parts section back in the mid 80s we used to sell a fair few of those.
If at first you do
CherryBomb Johnston Offline
#14 Posted : Friday, 31 October 2008 6:13:37 AM(UTC)
CherryBomb Johnston
If the nuts been ingested into the intake, its bouncing around between your pistons crown and your heads every time the pistons turning over top dead center.
removing you rock covers wont be enough. if you cant dig it out from the spark plug hole, the he
"Because stock sucks"
#15 Posted : Friday, 31 October 2008 6:43:40 AM(UTC)
basketcasebear
yes thanks cherrybomb.
i am not sure if there is a nut in there??
but it is interesting at what i found when i took r,r off.?
i will be getting magnet tomorrow, and with my trusty splark splug splanner, will see if i can find it in that pot?
it may be
DOH!!!
Guest (10)
