3914636 is number off a 307 chev. is it hk era??
HK or HT. Post the engine number and ill tell you what its from.
3914636 Block casting number is year 1968, 307 cu" Its a 2 bolt mains bearing, and 200 HP
While youre at it guys i have the same number on an engine. I assumed it would be american? It also has 307179 on the front block face. Thanks.
Ita actually a Canadian cast 307. 307179xx is from an early 5 litre auto HT built in the Pagewood plant. Could be any shape or luxury level HT except Brougham (which were 308), but probably from a GTS or Premier. _______________________________________ Edited by user Tuesday, 23 September 2008 8:16:46 PM(UTC)
| Reason: Not specified |
30714102 - K12 21 engine number
Approx October 1968 build HK Pagewood (Sydney) engine, assembled in the McKinnon (Canada) plant on 21/12/67. Probably Brougham, GTS or Premier but could be out of any shape or luxury level HK auto or manual, even a Belmont ute.
________________________ |
Hi PISTOF, do you want to sell or swap for 350? I have an early HT GTS originally with 307/powerglide and am trying to find its original engine. Thanks
Thanks for that mate. Hi tanart, its actually in the for sale secton (2nd page). Im not looking to swap, its in Brisbane though. Cheers.
tanart how much for 307. i needf one for a hk
