#1 Posted : Tuesday, 15 June 2004 5:42:36 AM(UTC)
Can anyone tell me where I can purchase a new old stock indicator assembly for my XC Falcon?
<p>
The one I have won't cancel out after I complete a turn. I think I need a new stalk...
<p>
THANKS!
#2 Posted : Tuesday, 15 June 2004 7:31:41 AM(UTC)
These pop up on EBay from time to time and sell for $200-$250. A mate has one in his shed but he wont sell it to me! Do you have an aftermarket steering wheel? I have a SAAS on mine and it only cancels after left hand turns but not right. Try tightening u
#3 Posted : Tuesday, 15 June 2004 8:43:52 PM(UTC)
There's a little black (might be white) piece of plastic between the steering wheel or steering wheel boss and the indicator assembly. There should be a spring also.
Replace that and it'll cancel out. Usually thats the bit thats worn it's a $10 part
#4 Posted : Thursday, 17 June 2004 6:29:35 PM(UTC)
Thanks...
#5 Posted : Wednesday, 31 August 2005 9:20:03 AM(UTC)
try fairford spares in padstow in sydney for ford spares. I had the same problem and it was that the plastic around the column that clicks the indicator of. If you can not find one of these black plastic bits call me i think i have a few floating around i
#6 Posted : Wednesday, 31 August 2005 10:04:40 AM(UTC)
It may also just be that one of the little springs on the indicator mechanism (the white or black bit referred to above) has broken or fallen off. There are usually two of them...check to see if both are still there.
If one (or both) are missing, I kno
