#1 Posted : Saturday, 4 October 2008 1:07:10 PM(UTC)
Got a question that I can find an answer to anywhere!
In regards to the HQ Monaro Coupe (GTS or other) were the bodies ever made in one City and manufactured in another?
Example;
The Body Number could be CHQxxxxxB meaning that the Monaro Body was made in Brisbane because of the B on the end. But the serial and Model on the Tags are saying that the Monaro is made in Sydney -
Model 82xxxx-S Serial 8Q37TDH82xxxxQ
Would the Monaro be legitimist or do the Tag numbers not matching the Car Body Number, because they state Sydney?
Any help, greatly appreciated.
Chris
#2 Posted : Saturday, 4 October 2008 6:09:18 PM(UTC)
Firstly yes Holden bodies were made in some plants and cars assembled in others but the chassis number always belonged to the assembly plant from what I have seen. The only HQ-HZ I know of where you get mismatching tags is HJ-HZ van and tonner bodies wher
#3 Posted : Saturday, 4 October 2008 10:10:14 PM(UTC)
Thanks Mate for the Info.
The following is the Numbers (the x numbers match so I didnt put them in);
1974 HQ HOLDEN MONARO GTS COUPE
Tag 1
Serial No 8Q37TDH8xxxxxQ
Tag 2
Model 80837QR
Body No 8xxxxx-S
Trim 1881-39X
Paint 567-15823
Engin
#4 Posted : Saturday, 4 October 2008 11:18:20 PM(UTC)
No. Chassis number belongs to assembly plant. The Body number is the bit that can differ when a body is made in one plant and car assembled in another. As the PSN matches on both the BODY and VIN plates the coupe that those tags originated on was built in
#5 Posted : Sunday, 5 October 2008 12:47:23 AM(UTC)
Yep; makes sense.
I am currently running a check on the Engine and Chassis Number - i will get back to ya in a few days.
Thanks again
#6 Posted : Tuesday, 7 October 2008 8:29:02 AM(UTC)
Thanks for ya help HK1837!
Did the check on the Chassis - definitely a 74 HQ Monaro Coupe.
The Engine is also definitely HQ, but possible out of a Sedan.
Thanks again for ya help Mate.
Chris.
#7 Posted : Tuesday, 7 October 2008 4:26:44 PM(UTC)
Did you get a search done for the engine number to see what chassis it was in? If the engine is original for the Sydney plates then that might give you the original Sydney chassis number? However if that chassis originally belongs to that body (which your
#8 Posted : Wednesday, 8 October 2008 6:26:57 AM(UTC)
Yer, youre right!
It would appear to be a re-shelled GTS.
The donor shell looks to be another GTS, either a 308 Model or more probable a GTS 350 from the look of some of the interior features. The donor shell and plates both come from a 74 HQ Monaro; th
#9 Posted : Tuesday, 21 October 2008 7:27:41 PM(UTC)
Looking at purchasing a 2 door Monaro body stamped number on the firewall right side is 11287s, also has other numbers AHQ112618.
Can anyone help with info to idenifiy year,engine,type etc ?
Cheers.
Garry
#10 Posted : Tuesday, 21 October 2008 7:43:55 PM(UTC)
Hi Garry.
The chassis number should read AHQ11261B (not AHQ112618). The last character should be a letter which identifies the assembly plant, in this case Brisbane. Also an AHQ was built in 1971.
Engine etc. cannot be identified by these numbers a
#11 Posted : Tuesday, 21 October 2008 9:39:22 PM(UTC)
Thanks for that Terry,
any help appreciated,the other numbers on the drivers side firewall mean anything. (11287s)
Cheers Garry (NZ)
#12 Posted : Tuesday, 21 October 2008 10:11:34 PM(UTC)
Chassis will actually be AHQ11261S if it belongs to the body. This is about right, the number on the firewall really means nothing but with AHQ Pagewood vehicles its normally close to the chassis which yours is. If the chassis does end in B it isnt origin
#13 Posted : Tuesday, 21 October 2008 11:29:03 PM(UTC)
More help please,
This chassis number is supposed to be a 1972 GTS (80169QH708193)
Can anybody confirm this,or tell me what vehicle this number fits.
Cheers Garry (NZ)
#14 Posted : Wednesday, 22 October 2008 4:27:04 AM(UTC)
That is the VIN number not the chassis number. It is off a Pagewood Sydney built HQ 6cyl Belmont sedan.
#15 Posted : Thursday, 23 October 2008 11:44:25 PM(UTC)
I have a HQ Holden 2 door Monaro with the number 11287s stamped into the driverside firewall.Can anyone help to indentifiy this vehicle,or give me some infot on it
Thanks Garry
#16 Posted : Friday, 24 October 2008 3:46:50 AM(UTC)
Gary, the number stamped intot he firewsall tells you nothing about the car, what you need is the numbers on the tags.
Warren
#17 Posted : Wednesday, 5 November 2008 8:47:57 AM(UTC)
hey guys just purchased a mint original hk kingswood sedan i was wondering if any one can help me with the numbers to see if it is a 6 or 5 seater originally it has two buckets in front at moment but i suspect they are monaro seats as they fold into centr
#18 Posted : Wednesday, 5 November 2008 7:20:28 PM(UTC)
All you can tell from the numbers is the car is an automatic sedanbuilt in Brisbane. Reclining buckets in sedan and Moanro are the same.
Warren
#19 Posted : Wednesday, 5 November 2008 9:39:19 PM(UTC)
Hi Garry,
Im sure this firewall number issue has been discussed here before as I can remember learning something new from it. The correct name for the number 11287S is the Vehicle Serial Number and on Sydney built cars it tells you quite a bit about th
#20 Posted : Thursday, 6 November 2008 12:25:39 AM(UTC)
Mike, this is not a firwall number, this is the number of the body id plate and incorperates model number and body number. The body number in HK has nothing to do with the PSN as in later vehicles.
Warren
This page was generated in 0.100 seconds.
