jimpram Offline
#1 Posted : Thursday, 9 October 2008 1:22:47 AM(UTC)
jimpram
I am stripping my HQ. What is the best way to rid body & panels of paint/rust etc. Some say Soda blast & others say Bead or sand blast. Does any one know the best procedure? Thanks.
#2 Posted : Thursday, 9 October 2008 1:57:58 AM(UTC)
Hi paint and rust=sandblast....,paint and some other stuff=bead blast.....,soda for just paint,this is what im hearing but i am useing paint stripper and grinding slow but such is the nature of a budget build.that way i dont have to strip the car right do
gmholdman Offline
#3 Posted : Thursday, 9 October 2008 8:00:17 PM(UTC)
gmholdman
Had my ute body "garnet" blasted, pretty sure sand blasting is outlawed now in Vic. It removed all bog and rust and was gentle on the door panels. I believe garnet is sent over from WA?? al.
bradk Offline
#4 Posted : Thursday, 9 October 2008 8:26:22 PM(UTC)
bradk
Had the channels in the doors and a couple of other things sand blasted because of the rust, and as long as your operator knows what he is doing with having his equip at low pressure and watch the heat build up you should be OK. He refused to do anythin
#5 Posted : Thursday, 9 October 2008 8:43:12 PM(UTC)
Have heard that Soda glosses the steel up too much and paint wont stick, but I know no more. Talk to someone that knows their stuff before doing anything.
If we all had the same (good) taste, who
ozchevy Offline
#6 Posted : Thursday, 9 October 2008 9:54:06 PM(UTC)
ozchevy
Ive got a mate who does this for a living, and he would be one of best around with 25 yrs plus experience in car body paint removal. He uses Garnet and says its the best method, if you know what your doing.
Hes done heaps of stuff for me and never warped
adam PERTH Offline
#7 Posted : Friday, 10 October 2008 2:58:35 AM(UTC)
adam PERTH
i recently sold a HZ 1 ton chassis, and, as part of the deal i had to drop it off to a soda blasting place.. In Navel Base
Lucky for ,me, the guy there gave me an extensive tour.
He said that all panels pressed from 1953 onwards are Zinc coated.
He wen
jimpram Offline
#8 Posted : Friday, 10 October 2008 3:48:07 AM(UTC)
jimpram
Thanks to all who have replied to this topic. Hopefully I get some more input/replies.
Tis he who asks that finds out................
scottxwgs Offline
#9 Posted : Friday, 10 October 2008 5:08:19 AM(UTC)
scottxwgs
hi mate soda blast is the best by far. As for paint not sticking, there is a process of cleaning after you soda blast that not many people know, thats why it dont stick. If you want more info and some contacts that know the process let me know. email scot
