Ado Offline
#1 Posted : Thursday, 9 October 2008 4:31:30 AM(UTC)
Ado
Are VB/VK wagon shockies interchangeable with the same model sedan shockies? Trying to build one good car out of two.Also are wagon and sedan rear doortrims the same and is it hard to fit vk door trims to a vb.
Thanks alot
Ado
Edited by user Thursday, 9 October 2008 5:25:38 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 9 October 2008 8:42:09 AM(UTC)
VB-VL sedan & wagon door trims all interchange - only difference is some have the sliding locks, others have the snipper pins, and neither really interchange (unless you swap the locks over) as the metal bit at the top is different for both.
Rear shock
#3 Posted : Thursday, 9 October 2008 8:49:17 AM(UTC)
Wagon shocks are longer.
If you put a wagon diff in your sedan and use lowered springs, use the sedan shocks.
The door trims should fit VB provided you have early VK trims, the later VK trims had a sliding lock instead of a lifting button.
Having
#4 Posted : Thursday, 9 October 2008 8:57:54 AM(UTC)
O.K
A bit of contradiction that might confuse?
Maybe the wagon shocks are shorter overall? If so, I stand corrected.
But sedan shocks will fit on a wagon diff in a sedan if you use lowered springs.
With regards to the bottom mount, just push the
Ado Offline
#5 Posted : Tuesday, 14 October 2008 2:47:13 AM(UTC)
Ado
Cheers for all the replies guys!
