basketcasebear Offline
#1 Posted : Thursday, 9 October 2008 7:51:35 AM(UTC)
basketcasebear
hey yall,
found out problemo from previous post, where was unable to figure out what had gone wrong with rear lights not workin?
fuse!!!
what shows me up to be a complete basketcase. is the fact i did not know the light switch had to be on,,,to test the fuses for lights???
the other fuses show good or bad, with nothing on,?? but not the light fuses,
so it wasnt main fusable link, as we suspected.
so i learned something,
now question>>
can i wire in the lights in one continuous loop??
eg,,go from one taillight to the next and so on? or do they need to be on separate loops?
same for brakelight?
with one separate for R,/Left blinker.
there are an extra two lights on the rear of the camperervan, at the top..
jolly spiffing look old chaps, but not sure on capability.
your assistance and help, gratefully accepted,
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
#2 Posted : Thursday, 9 October 2008 8:29:47 AM(UTC)
volts is pressure, amps is flow. volts is how much water pressure youve got at the tap, amps is how fat a hose youve got. the globes are sprinklers
now assuming youve got enough pressure and flow, either way will work. If you connect them in seies (loo
#3 Posted : Thursday, 9 October 2008 8:46:02 AM(UTC)
oh yeah, to explain the pressure and flow
in one case all your globes are connected in a big log of t pieces at the tap. they are all seeing the exact same tap pressure (this is parallel)
in the other case (your loop) one globe comes after another,
#4 Posted : Thursday, 9 October 2008 8:57:26 AM(UTC)
note that with this analogy we are pretending that once a sprinkler blocks up it means that no water can flow to the next sprinkler
mrhqute Offline
#5 Posted : Thursday, 9 October 2008 9:06:55 AM(UTC)
mrhqute
Yes. This is the way cars are traditionally wired
#6 Posted : Thursday, 9 October 2008 9:28:34 AM(UTC)
basketcasebear
Well shiver me timbers,,tie me kangaroo down sport, strike me pink, and how much can a koala bear!!!
what a brilliant way to eggsplain elurctricity!!!
well done,,anon,,,!!!
although i wont be pissin on the pavement..!!!
i will be putting a tee piece i
DOH!!!
#7 Posted : Thursday, 9 October 2008 7:48:19 PM(UTC)
christmas tree car lights, blow one change them all?lol
Jim in adelaide
