RJR Offline
#1 Posted : Sunday, 12 October 2008 3:45:57 AM(UTC)
RJR
can any one tell me what 2 speed wiper set up would be best for the FJ (humpie) thanks
edelbrock1 Offline
#2 Posted : Sunday, 12 October 2008 4:32:27 AM(UTC)
edelbrock1
Not sure if this will work on the FJ, but I used a HX variable speed unit rigged into the original HK set up on my HK. This gives me variable speed wipers.
HTH
#3 Posted : Friday, 17 October 2008 8:05:32 AM(UTC)
Its not easy, I used a custom made bracket, VN wiper motor, custom made wiper arms and a reversing lever set up so that the wipe pattern remains as per original, all in all was about 3 days mucking around
#4 Posted : Friday, 17 October 2008 8:26:03 AM(UTC)
hey mate i got one for me fb bnib from a place down in vic for a 160 but its the real deal old one but recoed with everything you need hit back if you want more details
Rod32320 Offline
#5 Posted : Friday, 17 October 2008 8:38:29 PM(UTC)
Rod32320
i used one from Castle Auto Electrics http://www.castleauto.co...XJzLmluaSthbGxzZWFyY2g= Im not sure whether Id recommend it though. I had to modify it a bit to get the wipers to cover the whole screen and its quite
#6 Posted : Saturday, 18 October 2008 3:31:31 AM(UTC)
I put an HZ one straight into an FC and then wired with HZ wiring and dwell controller.
Warren
#7 Posted : Monday, 20 October 2008 6:12:11 AM(UTC)
Dont forget though folks that the FX/FJ wiper motor is internal not in the engine bay the original wiper arms are also designed to attach to a motor that ocillates, not one where the arm rotates like more modern motors.
also the FX/FJ wiper arms dont bot
Plodge Offline
#8 Posted : Monday, 20 October 2008 9:48:14 AM(UTC)
Plodge
we sell wiper kits for hot rods that could be used on the FJ. They are 2 speed and mount under the dash, they run a cable and will allow you to have the wiper go from inside out on both.
The kit is $449 delivered within Australia and comes with motor,cab
RJR Offline
#9 Posted : Tuesday, 28 October 2008 4:23:33 AM(UTC)
RJR
Thanks for the info guys, much appreciated
