robbo123 Offline
#1 Posted : Friday, 17 October 2008 8:54:02 AM(UTC)
robbo123
Has anybody installed a bypass oil filter on their vehicle? If so, how long until the first full oil change? What criteria do you use to decide when to change the oil without doing an oil analysis? Ive installed an Australian designed filter (Jackmaster) and changed the filter roll at about 10,000Km and just topped up with about 1/2 liter of oil. So far, I've used 6 rolls and would have continued the same regime but my wife serviced the car and forgot to say 'no oil change'.
Any suggestions welcome - not about the wife thank you!
Robbo
#2 Posted : Saturday, 18 October 2008 7:49:44 PM(UTC)
Hi Robbo123,
Regardless of whether or not you have a bypass filter installed, you will still need to change your oil at regular intervals. The extra filtration is a good idea but it wont actually extend yor oil life. The oil in a car engine runs very hot
tenticles Offline
#3 Posted : Saturday, 18 October 2008 11:54:32 PM(UTC)
tenticles
BWAAAH HAAAAH HAAAAAAAAAAAAAAAAAH
Originally posted by Andrew
Hi Robbo123,
yes sonny, it's an HQ ute
David Offline
#4 Posted : Sunday, 19 October 2008 6:32:23 PM(UTC)
David
I knew a bloke years ago who never changed his oil. Instead, he topped up when required, and he regularly changed the filter. He explained that the oil gets dirty and changing the filter fixes this. The oil molecules break down and burn off and topping up
#5 Posted : Monday, 20 October 2008 3:19:12 AM(UTC)
Thank you for the advice - much appreciated. My car is about 18 years old with the original motor and is not butning oil so Ill keep testing the bypass oil filter to satisfy my own curiosity. I have just recently read a research report from the USA Depart
tenticles Offline
#6 Posted : Monday, 20 October 2008 7:47:03 AM(UTC)
tenticles
with todays engines and oils, prolly unnecessary, but it would help to keep your old girl in good nick
check out bobistheoilguy, i recall 1 member in there who had run a bypass filter in his car and not done a complete oil change in 20 or 30 years. (he
#7 Posted : Monday, 20 October 2008 10:21:55 PM(UTC)
The trouble with using a bypass filter and not changing the oil is that the filter will not remove acids from the oil.
Petrol is an acid and as such the oil becomes more acidic over time and will eat your bearings. This is why you should put fresh o
#8 Posted : Tuesday, 21 October 2008 6:30:21 AM(UTC)
Just had a look at bobistheoilguy.com - a great site for info on oil. The engine oil does become more acidic over time but the damage appears to be more of a problem when condensation (water) dissolves any soluble acidic compounds. Fortunately, my bypass
#9 Posted : Tuesday, 21 October 2008 6:21:50 PM(UTC)
I used a bypass filter for many years on various cars.The filter was made in Perth and was called a 4M filter. I dont think they make them any more. The longest use was on a 69 Fairlane 302 V8 which I did over 200,000 miles in without an oil change. I dro
tenticles Offline
#10 Posted : Wednesday, 22 October 2008 5:27:57 PM(UTC)
tenticles
OMG
thats gonna play merrry hell with the oil nazis ...
#11 Posted : Thursday, 23 October 2008 5:11:08 AM(UTC)
Thanks Jim. I did search the web and found many oil recycling sites. What they say is that the "base oil" does not wear out and can be recovered. Its the additives that are depleted. Apparently, when you use the bypass oil filter much of the dirt, metal p
