pont69 Offline
#1 Posted : Friday, 17 October 2008 7:14:59 PM(UTC)
pont69
Hey guys.
I tried installing an LSD diff centre with 3.55 crownwheel.. and the backlash was over 100thou. so i tried spacing it over.. couldnt get it anywhere near. so what i ended up finding out was that the LSD centre i have is a 2.7 to 2.9 ratio one.. and i need a 3 to 4.44 ratio centre. Am i able to use a spacer behind the crownwheel to fix the difference?
or do i needa bite the bullet and go out and find a higher end ratio LSD??
By the way, it's a salisbury.
202, 4 On The Floor, Salisbury. Just about as Aussie as it comes.
Cheers, James
#2 Posted : Friday, 17 October 2008 8:40:11 PM(UTC)
Was thanked: 605 time(s) in 572 post(s)
You are correct - 2.60 and 2.78:1 Salisbury are a different hemisphere to the 3.08, 3.36, 3.55, 3.9 and 4.44:1.
You used to be able to buy spacers for the Chev 10-bolt to fit lower ratios, but ive never seen one for a Holden. I think youll either have
pont69 Offline
#3 Posted : Saturday, 18 October 2008 12:22:14 AM(UTC)
pont69
ahh dang.
i have 2.78 gears, and also have a single pegger centre for the higher ratios.. might just go 3.55 on the single pegger
unless anyone out there knows where i can get a spacer?? :D
haha cheers
Get your feral little mittens off it!
Cheers, James
pont69 Offline
#4 Posted : Saturday, 18 October 2008 12:38:33 AM(UTC)
pont69
ok. i just had a very quick search around for a spacer and came up with this..
The landovers of the same era had salisbury diffs. ARB sells a spacer for the crownwheel.
Does anybody know whether this spacer is of any use for my purpose?
Cheers again
Cheers, James
#5 Posted : Saturday, 18 October 2008 1:21:21 AM(UTC)
on diffs i found the back lash in my banjo diff centres was not between the crown and pinion but caused by the wear on the caseing teeth thats the part one cant buy any more so i have to go to salibury just thought i would add my two bobs worth cheers
pont69 Offline
#6 Posted : Saturday, 18 October 2008 1:24:47 AM(UTC)
pont69
nah mate im rebuilding the diff. the backlash would take 2 years to be taken up. and by that time ill shatter the crown wheel. so what i really wanna know from anyone is, whether that ARB-RD03A will work fr my purpose.
Cheers, James
#7 Posted : Saturday, 18 October 2008 2:09:52 AM(UTC)
Salisbury is a type of diff construction, not a brand. Landrover will be very different.
pont69 Offline
#8 Posted : Saturday, 18 October 2008 2:13:35 AM(UTC)
pont69
yes but if the construction is the same, then why wouldnt the crownwheel etc? :S
Cheers, James
#9 Posted : Saturday, 18 October 2008 4:28:28 AM(UTC)
Put it this way, a 351 Cleveland is a 90 degree V8. So is a Holden 253. Nothing is interchangeable. That is about how similar a Holden 10-bolt Salisbury will be to a Landrover Salisbury.
If we al
pont69 Offline
#10 Posted : Monday, 20 October 2008 3:55:48 AM(UTC)
pont69
haha ok then.
Cheers, James
