musksell Offline
#1 Posted : Tuesday, 21 October 2008 4:01:05 AM(UTC)
musksell
Does anyone know if speedo comes out the front way or do you have to extract it somehow from underneath..?
cheers in advance
HQforme Offline
#2 Posted : Tuesday, 21 October 2008 4:59:08 AM(UTC)
HQforme
Um, if its anything like earlier models, i think there are screws in the back, then it comes out fowards, but dont quote me on it. And access may be a bit tricky?
"Silly modern cars"
HZute-efi-VS5L Offline
#3 Posted : Tuesday, 21 October 2008 6:16:31 AM(UTC)
HZute-efi-VS5L
remove the facia. there is a few screws around the top and bottom. to get to the bottom screws you have to remove the bottom dash pannel. under the steering column. the pannel with the fuse cover.
the you will see the screws. there is 3. make sur
www.stickthisdecals.com.au
