6pak Offline
#1 Posted : Tuesday, 28 October 2008 5:23:56 AM(UTC)
6pak
Hi Folks, The more I drive my old ZD, the more the wind noise rushing into the door gaps bugs me. At about 70mph it's really full on. Is this normal or have I scored a poor set of door seals (rare spares so you would assume they're good).
ZC-Cruiser Offline
#2 Posted : Tuesday, 28 October 2008 5:42:17 AM(UTC)
ZC-Cruiser
I think it is pretty normal - I have done a bit to reduce the wind noise on my ZC.
- ran a bead of Sikaflex around the quarter vents
- glued some rubber seals from Clark Rubber around the outside of the door window frames
I think the next thing I n
It's good to honk in a Henry
The Yeti Offline
#3 Posted : Sunday, 16 November 2008 4:42:33 PM(UTC)
The Yeti
Mine was noisier with new rubbers than the old torn ones, I dont know if it setteled down or I got used to it but it seemed to get etter as the rubbers aged
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
6pak Offline
#4 Posted : Monday, 17 November 2008 9:17:58 AM(UTC)
6pak
Thanks Guys
I'll start with Sikaflex on the quarter windows as it seems to be fairly noisy around there...after that I,m thinking a stereo might be helpful. :)
