basketcasebear Offline
#1 Posted : Thursday, 30 October 2008 5:06:01 AM(UTC)
basketcasebear
so yall,
http://i37.tinypic.com/2h2k03s.jpg[/IMG]
as you can see from the pic, the cast bridging clamp thingo, has broken,,
the push rod appears to be straight,,, and strangely the engine runs, does not backfire, and really seems to be running on all 8..??
figure that out!!!
could it be that the nut has simply vibrated out??
and broken the bridge thingo,?
can i check if that valve is ok,,while i have R.Cover off..??
if so how?
while r.r is off, what process should i take to clean, lubricate, and fix problemo?
thanks already,
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
Edited by user Thursday, 30 October 2008 5:07:08 AM(UTC)  | Reason: Not specified
DOH!!!
bundybluedog Offline
#2 Posted : Thursday, 30 October 2008 6:34:36 AM(UTC)
bundybluedog
if the thread is ok put a new bridging thingo in there if the thread is bad heli coil it i had one break on me and from a loose rocker bolt. if its an exaust that is broken the engine will still fire on all 8. if you live near brisbane i have heaps of the
#3 Posted : Thursday, 30 October 2008 7:08:31 AM(UTC)
basketcasebear
hey thanks bundy,
the thread is fine and dandy, but i am near vic nsw border,
Q, if i get new thingerijig bridge,,and put it back on, as it is sitting, if i tighten bolt down tight, will it be in correct position?
and if so, is there any product i coul
DOH!!!
#4 Posted : Thursday, 30 October 2008 8:02:20 AM(UTC)
bundybluedog
there called pivots and the bolts are tightened to 25pounds and are non adjustable so its fine just to put a new pivot in and tighten the 7/16 bolt down. you cant realy check the valve with out removing it. if the rest are fine im sure that one is aswell.
HQforme Offline
#5 Posted : Thursday, 30 October 2008 9:37:22 AM(UTC)
HQforme
I had a rocker bridge snap like that whilst i was working it...i think they can get a little brittle.
As was stated, theyre fixed position, so just bolt a new one straight in.
Be careful with the bolt though, use a torque wrench, theyre easy to over
"Silly modern cars"
#6 Posted : Thursday, 30 October 2008 10:05:12 AM(UTC)
basketcasebear
thanks bundy, hq, will find torque wrench, new pivots, and away we go,,,hope,,
i must admit it looks a tadd dry? maybe oil not pumping up? will give her a burl while i am watching,
thanks heaps
will let yyou all know how i go,
bcb
said th
DOH!!!
80737k Offline
#7 Posted : Thursday, 30 October 2008 1:22:55 PM(UTC)
80737k
Hey BCB,l When fitting them bridges, they have an arrow to ensure correct fittment. IIRC the arrow hasta face the valve but check coz im too sozzled to be sure whicvh way they go. (Im a six man myself but they are prolly the same for the eights too)
"J
Fossil fuels are YUMMY !
#8 Posted : Friday, 31 October 2008 4:57:42 AM(UTC)
basketcasebear
well thankee 737k..
now it is a MAD RUSH to turn the camper into a BOUNDLESS, PROFOUND BEAUTY, NOM DE JEU!!! OR CEST LA GUERRE,
will be finally on road hook or by crook, by january,,
bcb
said the weathercock to the wind,> "how tedious a
Edited by user Friday, 31 October 2008 6:46:19 AM(UTC)  | Reason: Not specified
DOH!!!
Sandman Offline
#9 Posted : Friday, 31 October 2008 8:05:40 AM(UTC)
Sandman
The arrows point toward the carb/inward.
When your tightening rockers bridges down, be aware the some will be tightening down when the valve is open, so be carefull that each pair of bolts is tightened down evenly, so that the bridge goes down straight,
#10 Posted : Friday, 31 October 2008 9:26:16 AM(UTC)
Did the bolt break?
There is a chance that whatever it was that got lost in the carbie in your other thread might now have made its way to the piston crown?
#11 Posted : Friday, 31 October 2008 10:54:39 AM(UTC)
basketcasebear
thanks sandman,
should i turn motor over so i tighten down when there is no load on rockers?
i am hoping to get new one tomorrow,
bcb
p.s
tips for cup are free.
said the weathercock to the wind,> "how tedious and monotonous you are, c
DOH!!!
#12 Posted : Saturday, 1 November 2008 6:22:36 AM(UTC)
basketcasebear
update,
put the new doobie in today, before i put the r.c back on totally, gave her a run,, belive it or not, it would not idle like it did before, but was alot smootherer,,
i listened to head, and that side had a slight whiring sound, the other side di
DOH!!!
This page was generated in 0.095 seconds.
