richard Offline
#1 Posted : Wednesday, 5 November 2008 2:42:04 AM(UTC)
richard
the engine wont turn over i need some advice on the wiring. could someone please help.
Edited by user Wednesday, 5 November 2008 2:43:50 AM(UTC)  | Reason: Not specified
richard Offline
#2 Posted : Wednesday, 5 November 2008 2:43:09 AM(UTC)
richard
red engine 308 sorry cant type.
trubluhq Offline
#3 Posted : Wednesday, 5 November 2008 7:39:02 AM(UTC)
trubluhq
Can u be more specific :
What was does to stop it working ?
How far will it go ?
(1) wont turn over with the battery?
(2) turns but doesnt idle ?
(3) idles then stops ?
Pls advise..John
richard Offline
#4 Posted : Thursday, 6 November 2008 2:47:52 AM(UTC)
richard
it will turn over but it wont spark at the moment there is no wiring at all.
richard Offline
#5 Posted : Thursday, 6 November 2008 2:49:53 AM(UTC)
richard
it has an elec ign. i would like a diagram or instructions on how to do the wiring. the dizzy has 2 wires, coil with + and -, alternator and starter motor.
thanks
bundybluedog Offline
#6 Posted : Thursday, 6 November 2008 8:07:26 AM(UTC)
bundybluedog
you will always have 2 wires on electric dizzy one will always be black
1. Check 12 volts supply when ignition is on.
2. make sure a 12 volt coil is
fitted.
3. Disconnect battery before commencing
distributor change.
4. Connect Black wire from d
Guest (6)
