HotRodder Offline
#1 Posted : Sunday, 9 November 2008 1:54:54 AM(UTC)
HotRodder
Sometimes when I go to start our automatic
it won't start and I have to run the Tbar through
the gears then then back to park and it then starts fine.
Does anyone know what needs replacing or maybe adjusting.
meecar Offline
#2 Posted : Sunday, 9 November 2008 4:21:01 AM(UTC)
meecar
check your park neutral switch. my VK done the same thing i changed the park neutral switch and it hasn't done it since
HotRodder Offline
#3 Posted : Sunday, 9 November 2008 12:02:14 PM(UTC)
HotRodder
#4 Posted : Sunday, 9 November 2008 9:38:35 PM(UTC)
Or your bushes in your shifter may be worn, depends what set up you are running. I had to re-bush my ZH T-bar as the factory unit runs the white plastic bushes in its pivot point below the T-bar itself.
This page was generated in 0.080 seconds.
