KyallSmith Offline
#1 Posted : Wednesday, 12 November 2008 10:33:01 PM(UTC)
KyallSmith
Ok just after some info...
ive noticed that a waterjacket bung in the side of my 202 is a bit rusty, the ones in the block i think theres is 3 or 4 of them, on the manifold side. Anyway one of them is a bit rusty and it gets a bead of water in it after i drive the car. i'm a bit worried about this as a have a few long trips planned for the car in the next few months, one to lorne and another to the Prom.
My questions are:
Could this Bung let go while im driving... causing me to lose all my water, over heat and stuff the motor??
Should i get it replaced? can i get it replaced?
and also is the cooling system pressurised? and if so, how much pressure?
cheers guys
"People make sacrifices every day... Mine's the enrivoment!"
#2 Posted : Thursday, 13 November 2008 1:09:43 AM(UTC)
You should replace them when they start to leak. Not that hard to do on the side, bugger on the rear though. Cooling system pressure is indicated on the radiator cap.
If we all had the same (good
KyallSmith Offline
#3 Posted : Thursday, 13 November 2008 1:26:19 AM(UTC)
KyallSmith
sweet thanx...
can i do it my self or do i need special tool/s?
also can i buy the replacements from repco or supercheap?
"People make sacrifices every day... Mines the enrivoment!"
#4 Posted : Thursday, 13 November 2008 3:13:39 AM(UTC)
Repco will have them. Replacements are normally brass. You can do them yourself but youll probably have to remove the manifolds to get to them. I normally just punch a hole in them and lever them out. Put a bit of sealant around the new ones and tap them
#5 Posted : Thursday, 13 November 2008 7:30:19 AM(UTC)
Welch plugs
http://www.engineproblem.com.au/welch.htm
59-Cadillac Coupe, 49-Triumph SpeedTwin, 74-HQ GTS4 Monaro, 06 350Z roadster
pont69 Offline
#6 Posted : Thursday, 13 November 2008 7:31:23 AM(UTC)
pont69
check on eBay. cheapest i found.. even cheaper than trade through work
Get your feral little mittens off it!
Cheers, James
KyallSmith Offline
#7 Posted : Thursday, 13 November 2008 6:16:16 PM(UTC)
KyallSmith
Thanx guys
ill get on to that this weekend.
Smithy
