Mr HT gts Offline
#1 Posted : Thursday, 13 November 2008 7:51:15 AM(UTC)
Mr HT gts
G'day
Ive got a old xy falcon and the horn has started to go on the blink, it will work and then it won't, if the car isn't on and you push the horn it will work, however if you have the lights on and the car is turned off it wont, however when its on and the lights are also on it wont work but if you rev it a bit for a couple of seconds it might.
when its not working properly, you can still hear it clicking ! its real weird, is the horn stuffed (its the orignal unit) ? or is a electrical issue ?
Cheers guys.
Paul351xb Offline
#2 Posted : Thursday, 13 November 2008 8:05:21 AM(UTC)
Paul351xb
Sounds electrical to me. Try running a relay to the horn. Over time the wiring builds up a larger resistence and things like this happen. Headlights playing up is another sign of aging wires.
Mr HT gts Offline
#3 Posted : Thursday, 13 November 2008 8:06:08 AM(UTC)
Mr HT gts
I just tried it again, you turn the car on it wont work, rev it a bit say 20 seconds just off idle and try it again and it works, stupid thing, it would have been eaiser if the horn just packed in !
if anyone out there has 70' 71 stamped hi\low fairmo
Mr HT gts Offline
#4 Posted : Thursday, 13 November 2008 8:07:51 AM(UTC)
Mr HT gts
Thanks paul i'll look into that, it's just odd that they were working fine on the weekend !
#5 Posted : Thursday, 13 November 2008 8:23:30 AM(UTC)
ya do wot everyone else does. buy a junk horn and wack it on and sell ya original one for $500,000.69 cents oin ebay (coz thats how much my bids always ge beaten for. :). Seriously , it is probably the horn. Not sure on a xy but with xc horns, there is a
HotRodder Offline
#6 Posted : Friday, 14 November 2008 3:29:37 AM(UTC)
HotRodder
I have a 1938 Ford trumpet horn fitted to my rod and is it loud.
#7 Posted : Friday, 14 November 2008 6:11:05 AM(UTC)
Have you checked the voltage to the horn when applied, tried another earth or checked your alternator charge rate?
You could also bench test the horn by itself to isolate your problem.
This page was generated in 0.196 seconds.
