hm69hk Offline
#1 Posted : Saturday, 15 November 2008 10:23:10 PM(UTC)
hm69hk
Hey guys i need a hint or two on removing my fan from under the dash
.2 screws from engine bay removed
.3 screws from under dash seen and removed
Im stuck at this point i cant see any more screws and she is still stuck tight any one have a diagram or link to help.
Bangers Offline
#2 Posted : Sunday, 16 November 2008 1:39:48 AM(UTC)
Bangers
What type of car?
hm69hk Offline
#3 Posted : Sunday, 16 November 2008 1:58:23 AM(UTC)
hm69hk
VS Commodore 96 Wagon.
#4 Posted : Monday, 17 November 2008 7:48:47 AM(UTC)
The problem is, the fam & motor is assembled into the air-con box, and then the box is fitted up against the firewall - preventing you removing the fan!
You need to remove pretty much the entire lower half of the dash, and then undo all the heater & A/
hm69hk Offline
#5 Posted : Monday, 24 November 2008 7:45:06 AM(UTC)
hm69hk
Thanks Mick sounds like a bigger job than i thought.i wasnt sure about the ac pipes a certain tool is needed to undo them too i am told.
#6 Posted : Monday, 24 November 2008 8:01:19 AM(UTC)
Nope, just an allen key in the clamping block at the top between them, and it releases them.
hm69hk Offline
#7 Posted : Wednesday, 10 December 2008 6:26:34 AM(UTC)
hm69hk
Thanks again
almost there....
