#1 Posted : Sunday, 16 November 2008 11:16:57 AM(UTC)
Does anyone know what I should use to sand my car back?
I was thinking i could use a wire wheel? any suggestions would be appreciated
special-k Offline
#2 Posted : Sunday, 16 November 2008 11:20:13 AM(UTC)
special-k
I have used the wire wheel when I striped my ute back but I also used paint stripper before hand to make it easier.There are also special paint stripping pads which go onto a 5" grinder which you can get from any good hardware store I found these to work
#3 Posted : Sunday, 16 November 2008 11:34:22 AM(UTC)
Cheers mate, will look out for stripping pads at hardware tomorrow
The Yeti Offline
#4 Posted : Sunday, 16 November 2008 4:22:25 PM(UTC)
The Yeti
depends on what you have to take off Ive used wire wheels and stripping pads (these are great but expencive) I also have a 7" sander polisher and its good jsut go easy or you can/will do alot of damge
See The Yetis Chev build at
http://www.ozrodders.c
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
#5 Posted : Monday, 17 November 2008 5:45:37 AM(UTC)
Best is first to use a chemical stripper- use gloves and in a ventilated area.
Then use a 7" clean and strip disc on a 7" sander. With this method you wont cut into the metal and will leave the surface ready to acid etch for primer.
#6 Posted : Monday, 17 November 2008 6:07:32 AM(UTC)
i used a flap disk on the end of the drill. i forget the name but its made by 3M.bunnings sell them. its recycled plastic bags. great for door jambs and gutter rails. for the big panel i just used paint stripper. i got a stanley knife and cut up the paint
This page was generated in 0.099 seconds.
