#1 Posted : Thursday, 20 November 2008 8:53:31 AM(UTC)
I have an old car that has oval holes 5 x 3' and i can't find anybody who sells this size speakers anymore. Also i can't buy the foam filter insert for the 'ramflo' filters either. Does anybody have any ideas?
HkDave
jabba Offline
#2 Posted : Friday, 21 November 2008 3:59:59 PM(UTC)
jabba
I had the same problem in HJ Naro rear parcel shelf. Ended up making a wooden spacer to fit under the speaker so that 6x4 cone sat in hole. Then put carpet over spacer with speaker grill on top. Ramflo filter elements you should be able to get away with
#3 Posted : Saturday, 22 November 2008 6:32:24 AM(UTC)
I will try both ideas. Thanks Jabba.
