HJHeaven Offline
#1 Posted : Sunday, 23 November 2008 11:02:35 PM(UTC)
HJHeaven
Hi all
Bit of a silly question maybe.
I have a red 308. What is the PCV valve from the rocker cover (rear near the dizzy - not the front one) connect to?
Thanks in advance
Mark
I am not allowed a mistress so i got a GTS - and its better
A GTS/4 is a monaro - so nuuur
vintageholden Offline
#2 Posted : Monday, 24 November 2008 2:13:26 AM(UTC)
vintageholden
air cleaner
JBM Offline
#3 Posted : Monday, 24 November 2008 3:05:23 AM(UTC)
JBM
On my VH there is actually no PCV in the back of that rocker cover, it just has a plastic spout, then a hose and then it enters the side of the aircleaner, on the inside of the air cleaner is a plastic piece that holds some scotchbrite type material.
J
HJHeaven Offline
#4 Posted : Monday, 24 November 2008 5:58:21 AM(UTC)
HJHeaven
Thanks guys - went to the Perth GM Show day today and saw that that is right. Thanks
jabba Offline
#5 Posted : Monday, 24 November 2008 7:27:52 PM(UTC)
jabba
There are two different vent mechanisms. I tripped over the difference myself.
A PCV has a check valve and spring in it connects to either the base of the carb or into the manifold and at idle is closed. The other is just a rocker vent , is open and
This page was generated in 0.022 seconds.
