#1 Posted : Tuesday, 25 November 2008 4:07:17 AM(UTC)
Are the speedo (driven) gears the same between top loader and other manual tranmissions (single rail, etc).
I've recently swapped in a set of 3.7's into my fairlane (has a top loader in it) and need a 21tooth speedo gear so the speedo reads correct. I see fomoco.com.au has 21T listed for single rail but not top loader, i thought they used the same gear? anyone know the answer?
thanks, NAthan
ZC-Cruiser Offline
#2 Posted : Tuesday, 25 November 2008 4:19:46 AM(UTC)
ZC-Cruiser
Borg Warner gears are different to Ford gears
The BW gear sits on top of the output shaft while on the Ford boxes (C4, Toploader etc) sit under the output shaft
They are not interchangeable - you'll need a gear to suit a Ford Box
It's good to
It's good to honk in a Henry
#3 Posted : Tuesday, 25 November 2008 6:28:53 AM(UTC)
How does she go with the 3.7 ratio, what revs are you pulling at 100kph?
#4 Posted : Tuesday, 25 November 2008 6:19:51 PM(UTC)
Thanks ZC for the info.
It drives alot better now, its actually possible to do a hillstart now without having to ride the clutch... Still, its about as fast as a 2ton car with a stock 351, pretty slow... Does about 3000rpm at 100kmh, dont use it on hte
#5 Posted : Wednesday, 26 November 2008 8:07:39 AM(UTC)
I weighed my ZH and it came in at 1640kgs? I have removed the air con and power steer though.
#6 Posted : Wednesday, 26 November 2008 5:31:17 PM(UTC)
2ton was a bit of an exaggeration, lol. I think standard kerb weight for a 351 marquis is about 1780kg. Bit lighter if you dont have elec seats, etc. The later ones are a bit heavier as they have intrusion bars in the doors, early ones dont.
Guest (5)
