bundybluedog Offline
#1 Posted : Friday, 28 November 2008 3:05:14 AM(UTC)
bundybluedog
Has anyone here put a T5 behind a 308 in LC torana i was wondering if its an easy conversion and couldi use normal torana pedals.
Are all manual pedals for toranas the same like LH in LC ect.
#2 Posted : Friday, 28 November 2008 6:18:05 AM(UTC)
I havent done the trans swap but you would need to change
the tunnel to make the gearbox fit,
I have a V8 in a LJ which is easy swap, but with aussie 4spd
LC/LJ pedals are same, LH/LH are same
can use LC pedal but would need to convert to full cable
#3 Posted : Friday, 28 November 2008 6:19:42 AM(UTC)
LH/LX ARE SAME
