#1 Posted : Saturday, 29 November 2008 8:17:43 AM(UTC)
Hi all
I have a Saginaw box to replace the trimatic behind my 308.
I have been told that the Saginaws have a Chev pattern bell housing. I have a bell housing to adapt the saginaw to the trimatic pattern.
My question, what crossmember do I need for the Saginaw?
Would it be the same for the T350/400?
mmazz30 Offline
#2 Posted : Saturday, 29 November 2008 8:59:19 AM(UTC)
mmazz30
Hi Roy,
When i changed my 253 trimatic to a saginaw in my HJ monaro back in the 80s i used the same crossmember.
I think i had to elongate the 2 trans rubber mount holes or drill the 2 holes further back/forward (20 years ago) sheesh!!
I also used the
#3 Posted : Saturday, 29 November 2008 6:18:06 PM(UTC)
If we are talking HQ-WB a TH350 crossmember is what you want. Early WB Statesman is the best bet to find one. If its a sedan/wagon/statesman itll bolt straight in. If its a ute/van/tonner just cout both ends off to make it the same width as the one you ha
