les Offline
#1 Posted : Thursday, 4 December 2008 1:06:18 AM(UTC)
les
Can anyone help with good samples of the following grommets?
7436595 GROMMET MAIN WIRING HK HT HG
7433371 GROMMET CHOKE HK HT HG 6 CYL EXCEPT 186S
7433191 GROMMET HANDBRAKE CABLE HK HT HG
SP1722 GROMMET WIRING THRU SKIRT HK HT HG
Les
Electraplater Offline
#2 Posted : Thursday, 4 December 2008 1:33:21 AM(UTC)
Electraplater
might have some samples, the sp1722 is the grommets where the front indicator wires go thru the skirt
the 7436595 is not for main harness, yellow book says body harness and there is nowhere I know of where the body harness has a grommet - only one close
les Offline
#3 Posted : Thursday, 4 December 2008 1:45:50 AM(UTC)
les
I should have looked the parts up myself 7436595 is the body wiring grommet for ute /van.
SP 1722 do you want to sell me a couple or would you like me to replace them with new ones when we make them
Les
#4 Posted : Thursday, 4 December 2008 1:57:09 AM(UTC)
Electraplater
Ill have to check what Ive got Les, will let you know by the weekend if nobody else can help
hazzard county Offline
#5 Posted : Thursday, 4 December 2008 5:22:40 AM(UTC)
hazzard county
gday les nothing to do with above but you said you were making d rubbers for hk t g swaybars are they available as yet also i checked my swaybar a few weeks back & notice that its not 24 mm but slightly smaller what do your holden drawings say about the s
les Offline
#6 Posted : Thursday, 4 December 2008 6:11:48 AM(UTC)
les
hazzard county
From memory I think the drawing said 22mm they should be available in Jan 2009. I can not help with the exhaust drawing
#7 Posted : Thursday, 4 December 2008 8:14:02 AM(UTC)
I have Genuine GMH factory drawings for the full 307 327 350 Monaro Dual /Twin System exhaust . But lent them to a guy called Ken Morrison in Shepparton. His numbers are 0419 000 724 or home 0358220223 . Tell him James from Monaro Muscle Parts sent you .
Guest (8)
