Davesmonaro68 Offline
#1 Posted : Friday, 5 December 2008 9:12:14 PM(UTC)
Davesmonaro68
Hey guys will the yoke of the small Sals fit to the bw diff as i need to use the one piece tailshaft i have .
BW has the flat flange and the other is the standard holden tye uni. Any help will be appreciated .
Dave
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#2 Posted : Friday, 5 December 2008 11:01:39 PM(UTC)
If you use the flange off the rear of a 6 cylinder VL tailshaft it will bolt to the Borg Warner flange and take the 6 cylinder Holden uni joints.
This may result in you needing a slightly shorter tailshaft though.
Alternately you could use the
#3 Posted : Saturday, 6 December 2008 6:28:04 AM(UTC)
Jim, the flange you need is off a 1985 VK Carby 6.
The 84 VK didnt have the B/W diff, it only came out on VK 6 cylinders in 85
The VK EFI 6 & VL run a bigger uni than the Holden 6 uni - only the carby 6 kept the small one.
Also, the tailshaft tub
#4 Posted : Wednesday, 10 December 2008 2:41:11 AM(UTC)
