Hey guys will the yoke of the small Sals fit to the bw diff as i need to use the one piece tailshaft i have . BW has the flat flange and the other is the standard holden tye uni. Any help will be appreciated . Dave
MONARO!!WHERE!!NICE |
If you use the flange off the rear of a 6 cylinder VL tailshaft it will bolt to the Borg Warner flange and take the 6 cylinder Holden uni joints.
This may result in you needing a slightly shorter tailshaft though.
Alternately you could use the |
Jim, the flange you need is off a 1985 VK Carby 6.
The 84 VK didnt have the B/W diff, it only came out on VK 6 cylinders in 85
The VK EFI 6 & VL run a bigger uni than the Holden 6 uni - only the carby 6 kept the small one.
Also, the tailshaft tub |
The VK EFI 6 & VL run a bigger |
