joelm Offline
#1 Posted : Tuesday, 9 December 2008 8:36:46 AM(UTC)
joelm
hi all,
am running twin 1 1/32 single barrel strombergs on speco inlet manifold on a warm grey.
I am trying to work out the best setup for the fuel lines, which of the following would give most balanced fuel to both carbies and efficient/power
Option One
carb1 carb 2
Option Two
carb1 carb 2
Thanks in advance.
The Yeti Offline
#2 Posted : Tuesday, 9 December 2008 3:58:02 PM(UTC)
The Yeti
mate Id love to try and help but I dont understand your dots and dashed, are you shipwreced of the east coast and want a pizza? or did pirats bord your vessel, my morse coad isnt that good sorry
keep in mind with thsi your running carbys so if the fuel
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
joelm Offline
#3 Posted : Tuesday, 9 December 2008 10:56:21 PM(UTC)
joelm
hi the yeti,
hehe thanks for that. didnt realise the picture would go all skew wiff..
basically i wanted to find out if i should run them to a t piece and then even lengths to each carby (option 1)
or
run direct to front carby, then to 2nd carby..
#4 Posted : Tuesday, 9 December 2008 11:29:06 PM(UTC)
A T-piece at the front carby will be fine. This is how X2s were done & they had bigger carby on a bigger engine.
The Yeti Offline
#5 Posted : Wednesday, 10 December 2008 12:41:37 AM(UTC)
The Yeti
the T peice will do exactly the same thing as the fuel block thats esentialy what it is
See The Yetis Chev build at
joelm Offline
#6 Posted : Wednesday, 10 December 2008 5:26:39 AM(UTC)
joelm
thanks guys.
so there is no benefit in running the t piece to match fuel line distances?
HQforme Offline
#7 Posted : Saturday, 13 December 2008 11:30:55 PM(UTC)
HQforme
Hi Joel, this is how ive set mine up, and its as Dr Terry said. If you think about it, the carbs draw fuel from the bowl, not the line, so as long as the fuel enters the bowl, youre set.
[IMG]http://i84.photobucket.com/albums/k30/abandoneveryhope/DSC00
"Silly modern cars"
joelm Offline
#8 Posted : Saturday, 13 December 2008 11:55:12 PM(UTC)
joelm
hqform- thanks heaps that that, ill head down to the parts shop and get it going.
quick final question- does anyone know where you can get the bar & screws that go on the front of the carby? the screw have stripped out on mine and cant get a reaplaceme
