HQforme Offline
#1 Posted : Saturday, 13 December 2008 11:35:28 PM(UTC)
HQforme
Just recieved a set of high pressure valve springs for my red 202. Theyre listed as the correct model, but to look at, they're significantly longer than standard ones. They're slightly slimmer and will no doubt compress a long way, but before i got putting them on i'd just like a second opinion? Cheers.
"Silly modern cars"
Luke in SA Offline
#2 Posted : Sunday, 14 December 2008 2:27:41 PM(UTC)
Luke in SA
Ring the supplier and check that you have the correct item..
adam PERTH Offline
#3 Posted : Monday, 15 December 2008 5:54:04 AM(UTC)
adam PERTH
they should be matched to your cam and lifters, whatever they are.
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Cheviot armoulite HQ
pair of 15" Dragway centrelines suit HQ
petaus Offline
#4 Posted : Monday, 15 December 2008 8:00:59 AM(UTC)
petaus
have you got the cam spec sheet? it should have installed height etc open spring pressure.
find a engine builder with a spring pressure gauge, you will need your installed height measured from your head, get the spring compressed to installed height chec
