#1 Posted : Sunday, 14 December 2008 8:23:54 AM(UTC)
i have a 304 complete engine from a VP. im going to run it on gas and its going into a HJ. looking at the prices for the T400 to T700. im happy with the T400. will this box bolt up behind the 304 block?
The Yeti Offline
#2 Posted : Sunday, 14 December 2008 4:46:24 PM(UTC)
The Yeti
yes its a turbo pattern block its all good but you might want to consder the etra $$$ it will be a much nicer car to drive wit hthe 700
See The Yetis Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
#3 Posted : Sunday, 14 December 2008 7:07:08 PM(UTC)
Keep the TH400 and run a taller diff. What you are doing is exactly what I did with my HZ Overlander.
In order to keep the VP water pump and fan use a HZ 6cyl with airon shroud, or a HQ 350 shroud also should fit.
_____________________________________
Dr Terry Online
#4 Posted : Sunday, 14 December 2008 9:06:31 PM(UTC)
Ive found the HQ-HZ 253/308 fan shroud does the job perfectly. The 6-cyl/350 V8 one suits a water pump which has its centre higher than the Holden V8. The Holden V8s water pump position didnt change height from HT to VT.
#5 Posted : Sunday, 14 December 2008 11:37:10 PM(UTC)
Terry, the HQ-HZ shroud wont work with the VPs fan with the square blades. I tried that and then found the 6cyl one fitted and worked perfectly. It was a with a HQ 350 5 row radiator, but these are no different in size to a 3 row as far as the fan and shr
#6 Posted : Monday, 15 December 2008 4:46:18 AM(UTC)
thanks for the replys guys. what do you guys think about going with thermo fans instead of factory fan. as the body is very standard looking with the faded paint and rust free straight body. so im doing the drive train first as its a 253 trimatic in there
#7 Posted : Monday, 15 December 2008 6:37:41 AM(UTC)
Most seem to use the Ford EF or thereabouts type.
