munro73 Offline
#1 Posted : Monday, 15 December 2008 10:44:03 AM(UTC)
munro73
hey all
need so advice on my xg van which runs gas and keeps popping off the line on the manifold which controls the heater controls
causin it to backfire etc etc
i keep putting them back on but they keep coming off?
any ideas on a perment fix?
marge pass me my gun
#2 Posted : Wednesday, 17 December 2008 6:45:00 AM(UTC)
Is it dual fuel or straight LPG? Have you checked your timing, lead set in good nick, right heat range spark plug and are your mixtures correct? Do you have any vacuum (air) leaks from your manifold gasket or anywhere else?
#3 Posted : Wednesday, 17 December 2008 6:46:06 AM(UTC)
Sorry, just re-read the question, is it the LPG causing it to pop off?
munro73 Offline
#4 Posted : Wednesday, 17 December 2008 10:17:51 AM(UTC)
munro73
dual fuel but running it straight(long story) leads and plugs 4 months old timing done at same time dosent seem off,just does the ford gas backfiring thing and the heater lines fall off,which causes a vacum leak and back firing again
and used to cause th
#5 Posted : Thursday, 18 December 2008 8:18:22 AM(UTC)
I have seen them where they usually blow the air box apart, But I would be asking why it is backfiring rather than trying to rectify the after affects. What colour are your spark plugs electrode/tip? It may gie an indication of burning lean.
6pak Offline
#6 Posted : Thursday, 18 December 2008 10:21:31 AM(UTC)
6pak
Hi, This is the mother of all long shots but is your muffler/exhaust system OK? Years ago my wife had a Toyota Seca that was doing exactly the same thing and it turned out to be a collapsed muffler. Like I said it's a long shot... :)
munro73 Offline
#7 Posted : Friday, 19 December 2008 5:27:12 AM(UTC)
munro73
ok will cheak plug colour at weekend,but how do i ajust mixtures?
the motors au? and runing a eb computer?
#8 Posted : Friday, 19 December 2008 6:23:31 AM(UTC)
Did you convert the AU engine back to distributor rather than the coil pack setup, and don't AU haeds have a sensor at the back of them unlike the EB engines, That is on the 6 cylinders anyway, or are you running a 5 litre?
munro73 Offline
#9 Posted : Saturday, 20 December 2008 6:08:16 AM(UTC)
munro73
yep dissy set up
sensor not needed runs all the xg/xh wiring
that sensors just for the clyinder deavtivation
changed timining cover injection too
m8t never again
should have put the vct motor in
lol
