basketcasebear Offline
#1 Posted : Wednesday, 17 December 2008 4:54:53 AM(UTC)
basketcasebear
hey yall,
quaudrajet carby,
my mate pulled it apart and gave me the A/ok,
he has since gone to spain, or south of france,, i think??
anyways,,when i adjusted 2 screws in for leaness, found they both screwed right in, with 308 still running??
choke has been tied up, as it was on gas?
i thinks to myself i did, that it is running a tadd rich??
certainly not blowin blue smoke, darkish smoke at high revs?
so,,,, men of the 308 fan club,
suggestions?
does i have to pull it apart??
or could there be another reason??
is it easy to fix?
thanks already
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
#2 Posted : Wednesday, 17 December 2008 10:25:01 AM(UTC)
BCB.
If you could turn both the mixture screws right in at the same time and it did not stall.
I would suspect that the base idle is set to high and that the carby is not running on the
idle circuit at all and that it is actually running on the primary
#3 Posted : Wednesday, 17 December 2008 11:04:39 AM(UTC)
basketcasebear
hey thanks hqss
will have a squiz on friday,
how does a basketcase adjust the base idle?
or is this too hard for novice?
bcb
DOH!!!
