#1 Posted : Friday, 12 November 2004 10:51:51 PM(UTC)
Hi all, I am trying to find the wiring for the throttle body IAC motor for a VN-VP so I can get the Idle Control working using a different ECU. Thanks in advance.
#2 Posted : Saturday, 20 November 2004 5:39:20 AM(UTC)
Jamie
I have some information from the VN manual, but I'm not sure it will help you.
IAC Valve Terminal A feeds ECM (Engine Control Managment module) terminal C4 via Green/White wire (443). It is labelled "IAC Coil 'B' Hi"
IAC
