#1 Posted : Thursday, 18 December 2008 9:52:58 PM(UTC)
Hey crew, I have recently purchased an xb falcon (taking me back to my first car - hence the name) and was pleased/frustrated to see that it had the classic falcon squeak from the front end. Several people have told me various things about what needs replacing in order to get rid of it. Some tell me a new set of shocks will do it, others tell me it will be many and varied suspension rubbers. Just after opinions from those who have had the problem themselves and gotten rid of it.
Docktor Offline
#2 Posted : Thursday, 18 December 2008 11:56:18 PM(UTC)
Docktor
spring saddles mate.
Tex Scrotum rides again Offline
#3 Posted : Friday, 19 December 2008 12:01:37 AM(UTC)
DAMN....they can drive you CRAZEY......and for some of us it's a pretty short drive!
My XA used to do it on and off for years,I tryed greasing this that and the other,I must have sprayed(drowned) the entire front-end in WD-40 and all with ZERO result..
#4 Posted : Friday, 19 December 2008 12:21:26 AM(UTC)
Thanks mate
Paul351xb Offline
#5 Posted : Friday, 19 December 2008 9:02:50 AM(UTC)
Paul351xb
Yeah pump some grease into the nipples, front and back of the shock towers if it's an early XB. Also check the sway bar bushes. If it's still squeeking after you grease it up a bit pop the bonnet and bounce the car up and down. See if you can pinpoint w
#6 Posted : Friday, 19 December 2008 9:24:50 AM(UTC)
no point , its spring saddles. Bet my left knacker on it.
#7 Posted : Friday, 19 December 2008 7:36:29 PM(UTC)
Where do I get Spring Saddles from and how big a job is it in changin them?
Docktor Offline
#8 Posted : Friday, 19 December 2008 8:23:17 PM(UTC)
Docktor
Any auto store should have em. here is a pic so u know what u lookin for.
http://cgi.ebay.com.au/F...WDVWQQrdZ1QQcmdZViewItem
1. jack the ca
Paul351xb Offline
#9 Posted : Saturday, 20 December 2008 5:52:03 AM(UTC)
Paul351xb
If you have a grease gun try pumping in a bit of grease before pulling it all apart.
keithholden Offline
#10 Posted : Monday, 29 December 2008 4:30:39 AM(UTC)
keithholden
XW falcons always squeak but to fix it is easy, As paul said about the grease, BUT with one small tip, jack the car off the ground let the wheels hang them grease them, you usually have to do this 2 or 3 times over a period of a few weeks, works a treat,
Guest (8)
This page was generated in 0.214 seconds.
