meecar Offline
#1 Posted : Monday, 22 December 2008 3:08:06 AM(UTC)
meecar
Hey all, I have a vk with a standard 202 black motor it was running fine and then all of a sudden it started to splatter like it was missing but if you leave it over night it will start and run fine if you turn it off and leave it for 5 minutes or so and turn it back on it splatters like it has flooded itself i should also mention that it does this on petrol and gas 1 other thing i have noticed is the E.S.T light comes on off a fare bit.Thanks in advance. cheers
peter_flane Offline
#2 Posted : Monday, 22 December 2008 3:24:27 AM(UTC)
peter_flane
I have seen this happen before due to a blooop faulty air flow meter connection, and also because of a dry solder in the computer box. Check all connections first to computer, air flow meter, injectors, throttle position sensor, teperature sensor etc.
meecar Offline
#3 Posted : Monday, 22 December 2008 3:34:04 AM(UTC)
meecar
hey i will check some of those but i forgot to mention that it is a carby model
peter_flane Offline
#4 Posted : Monday, 22 December 2008 4:22:42 AM(UTC)
peter_flane
Ohh I see. Dont worry about what I have seen then, as it wont help with the carby at all. My bad.
kraul Offline
#5 Posted : Monday, 22 December 2008 7:34:15 AM(UTC)
kraul
i would check the est system though. The crank sensor and maybe try swaping the ecu with a known working one. I know they are tempremental
