hztonner Offline
#1 Posted : Tuesday, 23 December 2008 6:38:20 AM(UTC)
hztonner
as i have just bought this car in g.c run well
but just asking if anyone can help me if anyone knows what can be
causing this it only does it know and again
it does not run hot so please help thanks cheers allen
yes it is centre point injection (ALL IT WAS AT THE END WAS A BLOWN HEAD CASKET)
(SO AS IT GOT HOT IT WAS LETTING SOME WATER IN)
(TO THE CYL'S 1 & 6 IT IS THE STEEL AROUND THE)
(HEAD GASKET RUSTED AWAY AS TO TO LET WATER IN) (JUST LETTING KNOW CHEERS )
old fart racing the older i get the faster i was
Edited by user Wednesday, 11 March 2009 5:55:10 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 23 December 2008 6:48:31 AM(UTC)
Is it just straight Petrol,no LPG? Check for air leaks from the inlet manifold which will cause a lean mixture.
Are you running correct and good quality spark plugs, leads, dizzy cap and rotor arm? Is the timing slightly retarded?
Some of the Falcons re
Paul351xb Offline
#3 Posted : Tuesday, 23 December 2008 6:50:31 AM(UTC)
Paul351xb
Does it during acceleration or when just cruising? Hot, cold or both?
Could be something as simple as a lead going.
munro73 Offline
#4 Posted : Tuesday, 23 December 2008 8:54:33 AM(UTC)
munro73
check all your vacum hoses as well one may have poped off
check your dissy to
marge pass me my gun
hztonner Offline
#5 Posted : Tuesday, 23 December 2008 6:17:28 PM(UTC)
hztonner
Does it during acceleration only if i put my
foot into it ? Hot, cold or both?
it is only 6 cyl 4 litre it is not fuel injec
its the other as for helping thank you if any idea
come into you guy just let me know thank merry xmas
cheers allen
old f
#6 Posted : Tuesday, 23 December 2008 9:33:32 PM(UTC)
It has the large round air cleaner on it does it? If so, it still is fuel injected, it is called centre point injection.
Paul351xb Offline
#7 Posted : Wednesday, 24 December 2008 1:46:12 AM(UTC)
Paul351xb
Only during acceleration. Few things come to mind. Lead breaking down, crap plug or if all else fails try this. On the side of the dizzy is a wire. I runs along the block under the exhaust manifold. This has a habbit of cooking and going brittle whic
munro73 Offline
#8 Posted : Wednesday, 24 December 2008 8:40:33 AM(UTC)
munro73
yep that one got me on mine lol talk about mind f@@@ks
nearly through a match at it
hztonner Offline
#9 Posted : Wednesday, 24 December 2008 8:54:28 AM(UTC)
hztonner
hi i will check out all of these thing and get
back and let yous know how i get on thanks merry xmas
cheers allen
hztonner Offline
#10 Posted : Wednesday, 11 March 2009 5:57:08 PM(UTC)
hztonner
