PISTOF Offline
#1 Posted : Tuesday, 30 December 2008 7:37:51 AM(UTC)
PISTOF
Quick question for someone in the know before i place a wanted add.. What is the widest 14 inch standard HQ rim available. I need standard so i can still use hubcaps and dress rims. Cheers.
HQforme Offline
#2 Posted : Tuesday, 30 December 2008 7:53:56 AM(UTC)
HQforme
Um, stock was only up to 7? Might be wrong though. But you can get stock rims widened. Its a look im a big fan of.
Edited by user Tuesday, 30 December 2008 7:57:43 AM(UTC)  | Reason: Not specified
"Silly modern cars"
#3 Posted : Tuesday, 30 December 2008 8:14:53 AM(UTC)
Me Too ,Im a big fan do 8s you ll be better off they will look awsome!
Jim in adelaide
PISTOF Offline
#4 Posted : Tuesday, 30 December 2008 8:41:38 AM(UTC)
PISTOF
HQforme, im glad you edited. Yes i realise they can be widened, if they come in 7s i wont have to.. which is why i asked the question.
#5 Posted : Tuesday, 30 December 2008 9:43:45 AM(UTC)
HQ GTS rims and one Tonner rims are 6 inch and the widest from the factory at the time.
HJ had the release of the honeycomb rim and these are 7 inch wide
vintageholden Offline
#6 Posted : Tuesday, 30 December 2008 11:56:49 AM(UTC)
vintageholden
you can get 15x10 if you want
with 14" center so you can use 14" hub caps....
buy the 15" outer rim and have your 14,s welded in.
cost me $40 to get done plus $120 per rim
summerfield engineering W.A
Summerfield Engineering is a Wheels & Rims Shop
Edited by user Tuesday, 30 December 2008 11:59:23 AM(UTC)  | Reason: Not specified
PISTOF Offline
#7 Posted : Tuesday, 30 December 2008 12:21:14 PM(UTC)
PISTOF
Thankyou stuart, much appreciated.
Thanks vintage holden but i dont understand how you weld a 14" centre into a 15" rim.
Anyway im only using a 24x8x14 slick.. its all i can fit under an untubbed LJ and prefer to keep the standard look. Thanks.
#8 Posted : Tuesday, 30 December 2008 4:18:01 PM(UTC)
You can buy 15" rims with a step down in the middle to take 14" centres.
#9 Posted : Wednesday, 31 December 2008 1:36:25 AM(UTC)
what are these step down rims off so i check them out ?
#10 Posted : Wednesday, 31 December 2008 2:43:36 AM(UTC)
They are new specially made hoops so you can weld in centres off skinny 14" rims like GTS etc. Talk to Neale wheels or someone like that.
If we all had the same (good) taste, who would buy all th
adam PERTH Offline
#11 Posted : Wednesday, 31 December 2008 5:11:23 AM(UTC)
adam PERTH
i brought the last 5 14 x7 rims off ROH in about 2005.
$220 set.
They Look good on my HJ statesman, lowered slightly with original caps and trims.
they may have made another batch since.
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Che
#12 Posted : Wednesday, 31 December 2008 6:39:47 AM(UTC)
vintageholden
rare spares in welshpool have them in stock and on display
