HZpanelvanandsedan Offline
#1 Posted : Thursday, 1 January 2009 5:06:52 AM(UTC)
HZpanelvanandsedan
I have a problem with my XD transmission which I need to sort out. The gears won't engage. At present the tranmission fluid is fairly low, which I aim to top up and then see if that eliminates the problem. The only thing is, I can't work out what type of transmission fluid to use. How do I tell what type of transmission it is?
I noticed the gasket pan is leaking, which from initial inspection may be a gasket/seal and will be looked into before I refill trans fluid.
I know its a 3 speed cruisomatic (trans B), 4.1, engine W as listed on the tag codes, build date is 08-80, 5 seater!!
Pics of the trans are here:
http://gallery.oldholden.com/ecoimpact/XD/
I found these codes stamped on the tranmission
C6AP-7D027-B
8.0 D4ZP-7A040-AA
There was a big letter 'B' near one of the above codes too.
Could someone please help with some information. Greatly appreciated in advance.
Jesse
Paul351xb Offline
#2 Posted : Thursday, 1 January 2009 7:20:26 AM(UTC)
Paul351xb
Get some dextron 2 or 3 automatic fluid or whatever they call it now. Low fluid will cause your gears not to engage. You'll probably hear the pump whining a bit too as the torque converter tries to engage. Running the box that low on oil is not a good
#3 Posted : Friday, 2 January 2009 9:50:02 AM(UTC)
Don't fords use the "Type F" fluid????
Reason I ask, is I got some once (by accident), for an old trimatic, and was told in no uncertain terms by an 'old school' mechanically minded neighbour to only put Dexron 2 into the trimatic, as the Type F would
Paul351xb Offline
#4 Posted : Friday, 2 January 2009 10:33:22 AM(UTC)
Paul351xb
i think you will find the stuff they make now is ok to use in all the old boxes. well that's what they claim anyways. I'm running dextron 3 in my FMX. works fine. In the past I know there were 2 different oils made for the ford and holden boxes and ne
#5 Posted : Wednesday, 7 January 2009 5:01:00 AM(UTC)
HZpanelvanandsedan
