Have fitted pbr cast iron calipers to HT stub axles.The calipers are mounted on the back.Had to grind down the caliper to get bottom bolt to fit. My question is the flexible brake line takes a very twisty path and doesn,t look happy.Is there another, say right angle fitting that would work and is readly available? Thanks
Sounds a bit like you didnt swap the stub axles from left to right. Calipers should be on the front. This has been discussed many times on this forum. Do a search for it and you will no doubt find detailed instructions on how to do the conversion.
What you really want are L34 calipers mounted on the front (with reversed stubs). These have a plug in the bottom hose entry and have a top entry hose. You can modify stock HQ ones to do the same thing. If you want to do this I can take a picture of some |
Thanks Byron if you could post a photo and tread size that would be great.I tried the reverse trick but the brake lines where then not long enough to mount in the original position on the body.They also seem to foul the top wishbone.So not reversing the a
Send me an email address. Thread size for the top entry hole is the same as the botom thread.
Just had custom flexible rubber lines made. Converted line to a bolt through fitting at caliper end so you can swivel the line to the angle thats best.Original fitting still to match the body. Had line made 25mm longer than original to allow for better cu
marge pass me my gun |
