#1 Posted : Sunday, 4 January 2009 7:55:20 AM(UTC)
Having a problem lining up rear mount on a HG ute.Engine mounts are new and correct sides fitted.also a new hadfield g/box x/member,Extension housing hits on the top LHS bolt on the floor brace.Its possible to move to the right but the lower g/box mount is then off centre.I have had the front crossmember rebuilt with all new bushes and pads etc,is it possible it can be misaligned??I was to understand V8 and 6 front crossmembers are the same,is this correct?? is it possible th350 trans are different in length?? Also the drag link hits the oil pan on the LHS,please help!!!
petaus Offline
#2 Posted : Sunday, 4 January 2009 7:59:13 AM(UTC)
petaus
do you have your engine mount adaptors on the right side at the front? the taller one is for the r.h side from memory.
pete.
#3 Posted : Sunday, 4 January 2009 8:51:26 AM(UTC)
Hitting the floor with the box is normal.
Get a ball peen hammer and massage it up a bit. It does not need much to clear.
Also the drag link problem is the same as my car was before I lifted up the gear box by doing the above.
Cross member should
#4 Posted : Sunday, 4 January 2009 9:18:28 AM(UTC)
thanks team g,i have learnt there is different lengths in th 350s,mine is a direct import,massage is possible,also i have a thicker rear mont for that extra clearance,cheers mate
