HQforme Offline
#1 Posted : Sunday, 4 January 2009 10:10:39 AM(UTC)
HQforme
Ok, ive seen some posts in various places that recommend brass gears for the dizzy in a red 202. But both my old points dizzys, and the new HEI dizzy that i've installed, have plastic gears. Is this a problem?
"Silly modern cars"
#2 Posted : Sunday, 4 January 2009 10:52:39 AM(UTC)
As far as i know the plastic ones are fine.they are plastic so that if anything goes wrong they just strip (cheap an easy fix)
Jim in adelaide
#3 Posted : Sunday, 4 January 2009 11:12:04 AM(UTC)
I have heard stories of steel gears wrecking the cam drive gear when fitted to the dissy.
The way I think about it is that the oil pump has a steel gear standard, has more load than a dissy and drives off the same cam gear, so there should not be an is
